I use the magnets to replace the screws holding the upper and lower hulls together. It makes it a whole lot easier to open. I drill out the screw posts with a 1/4" bit and glue a magnet into the upper hull posts. When that is dry, I put the two magnets together and then glue them into the lower hull posts. I fit the hulls together before the glue dries and perfect fitting top.
Herman
