RCU Forums - View Single Post - How Much Damage? (part 2)
Old 04-15-2015 | 06:22 AM
Sport_Pilot's Avatar
Sport_Pilot
Originally Posted by FLAPHappy
Brad: I voted for major damage , and yes the engine will shut down. When an object is induced into the impeller blades, it will fracture a few blades, then those blades compound the problem fracturing more blades. You end up with with an implosion in the engine.
Engines are tested with 8 pound birds so I doubt it. Most of the fan blades may go through the bypass and not damage the power turbine so likely only a loss of power from vibration of main fan blade and no damage to compressor blades. Though your scenario is possible (random odds on this), even the turbine can injest a few blades and keep running, but then the power would be real low.
