RCU Forums - View Single Post - Paritech Natrix Build
Old 04-15-2015 | 05:09 PM
berthoud
My Feedback: (35)
I then started the stab. Much less work. Just had to open up the servo holes to accept the Futaba BLS HV servos, make a small oval to pass the servo wire out towards the fuse, and make the pushrod. I Aeropoxy a CF sleeve over the running length of the 3mm threaded rod. I also added a tube to the alu tube where it is taped to prevent stripping of the thin alu with time.
Plenty of high quality materials and glue in the critical areas.
ID:	2089396   Click image for larger version
ID:	2089397   Click image for larger version
ID:	2089398   Click image for larger version
ID:	2089399   Click image for larger version
ID:	2089400   Click image for larger version
