RE: Engine wont start
It sounds rich to me. When you pump excessive fuel into the carb with the glow ignitor on it will burn it off. But when you take it off the plug can't stay hot enough. Lean you Low end adjustment in about a 1/8 of a turn and try that then turn it another 1/8 if that doesn't work.
