RCU Forums - View Single Post - Servos for full Flying Stabs
Old 04-17-2015 | 04:05 AM
  #31
mikes68charger
My Feedback: (34)
Originally Posted by grbaker
The anti-rotation bolts in your stab pivot shaft are anchored into honeycomb. The play in your stabs is going to get a whole lot worse in just a few flights unless you cut into them and modify/repair them.
Won't matter how good your servo or linkage is.
While yes I agree with you it looks as they may have learned something from this site,
My shafts came attached to ply with a outer support of honeycomb then topped with 1mm carbonfiber
I did cut into the elevators on both sides of the pivot point. The filled holes in the honeycomb to lit the bolts pass through without contact so I could see the ply
There was also triangle peace of balsa attaching the shaft support to the root peace of ply that the main shaft goes through.
I still added some basswood to add support, aropoxy the spaces around the bolt holes and honeymoon, and added hard wood peace with holes drilled in to support the Bolts over a wider area.
