RCU Forums - View Single Post - How do I remove dried castor oil from an engine?
Old 04-19-2015 | 05:26 PM
JPMacG
Your old engines may be the iron piston / steel sleeve type. I have heard that these run better with castor deposits. I think the castor varnish helps with compression.
If you are interested in displaying your engines then yes, clean them using the methods mentioned. If you are interested in running them then I would just free the piston and carb up with some fuel and see how they run.
