Originally Posted by
Mr Cox
In terms of function the airbleed could well be facing backwards by rotating the whole carb 90°, I have done that on other engines.
On this engine though the carb is very asymmetric in shape, it doesn't show so well in the pictures above, but the section with the airbleed screw is sitting on a bulge on the carb. This bulge puts the screw very close to the prop, and it will also hit the cylinder if one rotates everything by 90°.
When you turn the carb 90 degrees, do you recommend putting the needle valve into the prop arc, or into the cylinder?
Agree on engine colors- but there are a few exceptions. The purple West .50/.52 for example. Hmm, what else now..
