Along the edge of your glow plug you should be able to see a little F indicateing that it is a four stroke plug . Sometimes turning your needle open a wee bit more will help it start . Also if you are flooded pull your plug and spin the enging over with the starter . If fuel sprays out it was flooded . If not opening the needle a bit might help .
