A Tiger 60 is a fantastic plane I have Two of them One I have been flying for three years that has a OS 75AX on it an one that I built over the winter that hasent been flowen yet . It has a OS 95AX on it . Tigers are not really a beginner plane but more of a second low wing trainer . However they are very easy to fly . Someone mentioned the importance of using caution around your prop once you get your engine started . I second that . Don't let the excitment of things get in the way of saftey . The prop becomes invisable and it is very easy to accidently pass your hand thru with out thinking or if the plane is not properly teathered when it starts it can leap forward . Also it is easy to accidently bump your throttle stick from low to wide open .. It is very important to be carefull .This hobby is very fun but it is also very dangerous .
