A hot knife or wire is about the only thing you can easily. If you can take the rib off of a razor saw, you can sometimes saw away the bond. I've done that but it is a lot of work as it is hard to work the saw back and forth with no grip on it. I've also attached an Xacto blade to a soldering iron and with the blade hot it will go through the epoxy but leaves a mess.
