Newbie mistake HELP
A hot knife or wire is about the only thing you can easily. If you can take the rib off of a razor saw, you can sometimes saw away the bond. I've done that but it is a lot of work as it is hard to work the saw back and forth with no grip on it. I've also attached an Xacto blade to a soldering iron and with the blade hot it will go through the epoxy but leaves a mess.
My Feedback: (-1)
A bit late with my answer but if you just use your covering heat gun you can always heat up the epoxy and just lift the parts off the plane and re-glue them back on. I really shouldn't know that but I have been known to use this little trick a couple of times. Works like a charm and you can wipe off the old epoxy while it's still hot so you have a like new joint.
