RCU Forums - View Single Post - OS FL 70 Piston Removal
Old 04-29-2015 | 11:46 AM
Ottdave
Never mind. Got the piston out. There was so much corrosion/gunk on the wrist pin that the rod would not slide over far enough to remove it from the crankshaft. Penetrating oil and a lot of working the rod back and forth did the trick. After run oil people. Use it!
