OS FL 70 Piston Removal
I recently obtained an old FL 70 four stroke in a purchase of several planes. I would like to replace the bearings but am having trouble removing the piston and rod so I can take out the crank. I have removed the cylinder sleeve but can't determine how to remove the piston/rod from the bore. How do I do this?
Never mind. Got the piston out. There was so much corrosion/gunk on the wrist pin that the rod would not slide over far enough to remove it from the crankshaft. Penetrating oil and a lot of working the rod back and forth did the trick. After run oil people. Use it!
