RCU Forums - View Single Post - Newbie mistake HELP
Old 05-01-2015 | 04:31 PM
Gray Beard
My Feedback: (-1)
A bit late with my answer but if you just use your covering heat gun you can always heat up the epoxy and just lift the parts off the plane and re-glue them back on. I really shouldn't know that but I have been known to use this little trick a couple of times. Works like a charm and you can wipe off the old epoxy while it's still hot so you have a like new joint.
