RE: Best way to install Robart hinge points
I used to use epoxy until I used the Pacer Hinge glue like rcpilot did. It works great and you wipe up your mes with a wet towel. It comes with a thin applicator tip that allows you to squeeze the glue down in the hole. The glue is set in about 15 min. I even used it to glue my Sig Mini field box. No more epoxy for me.
