RCU Forums - View Single Post - Do I have a bad cell?
Old 05-07-2015 | 06:01 PM
Edgar Perez's Avatar
Edgar Perez
My Feedback: (13)
Originally Posted by weatronic Support
your Transmitter is not charged. Please switch it off. Charge it witch the delivered Charger until the LED Ring is green. Then switch the Transmitter on. take a look (or screen shot) of the Battery Manager.
Jens,
After more than 48 hours connected in the charger, it seems there is a problem with my system.
I loaded a video of the Tx behavior before disconnecting from the charger. You will notice that the red light is blinking, then the system will make a short 'popping' noise (like when you turn it on) and the light will turn off. Shortly after the re light will start again and the cycle repeats.
https://www.youtube.com/watch?v=5eJDWW4dD-4&feature=youtu.be After disconnecting from the charger and turning the system on, the battery manager shows the following:
Note that in the video you don't hear the alarm because I used a switch to turn the volume down.
So what to do now? Don't think I can trust using the Tx this way.
