RE: senior telemaster / flat wing
I've built three, the latter two with a flat wing. The flat wing is far superior for most applications. However, if you can't use the rudder in conjuction with the ailerons, don't do it as some manuevers do require coordinated rudder/aileron with the flat wing.
