RCU Forums - View Single Post - Gearbox identification help
Old 05-13-2015 | 05:34 AM
Captain Nemo12's Avatar
Captain Nemo12
You'll have to solder on the RF noise reducing capacitors to the motor terminals. Usually the rating is 0.01uF to 0.047uF, you can find these at an electronics surplus store or simply desolder them from the stock motors and re-solder to the new motors in the same arrangement. You will also need a pinion gear remover.
