I played around with my SD10G, and when I got to the the point where you can change the settings , put your switch in the third position, and press the "Yes/+" button to make it go up, if the original setting is below the 20% setting, and the "no/-" button if the original seting is above the 20% setting you are trying to achieve!
I hope this helps..
Craig.
