Hey Preston,
If the clutch is slipping we have an upgraded ring gear and clutch plate that will solve this problem.
The clutch plate has an array of slots cut into its outer edge, and then tabs at the edge are bent up at a slight angle. These tabs then engage with shallow notches that are cut into the underside of the ring gear. This couples the two parts together, preventing any slippage.
Tell your buddy to send me an email. and we can send him upgraded parts.
Brenner ...
