I have found that quite a few of the new analog servos are likely using the same firmware that their digital counter part is using, because they do handle 333Hz (3ms) frame rates from gyros and flight stabilization systems. Futaba's frame rate is either 7ms or 14ms, depending on the setup. The X10+ board does pass the input frame rate to the servos.
