RCU Forums - View Single Post - Great Planes Sequence 1.20 Build Thread
Old 06-02-2015 | 08:38 AM
  #56
JAS's Avatar
JAS
My cowl ring was 1/32" short on the sides. Here's what i did to fix this.
I marked where the ring was short so I knew where to add wood to.
I marked some 1/32" plywood for what I needed.
Then I cut the strips (any way you want to cut it, scissors was my way).
Using some Medium Zap, I glued them on between the marks.
Then i finished it with a final sanding to fit the fuse.
Next is motor mounting. I am spacing it out a bit so the cowling fits 'better'. I'll explain once it's done.
ID:	2100039   Click image for larger version
ID:	2100040   Click image for larger version
ID:	2100041   Click image for larger version
ID:	2100042   Click image for larger version
