Originally Posted by
Jmiller70
Got almost everything squared away, but the recoil. Does the Taigen IR recoil system need modification to work with the Clark board, the elevation works, it's slower, more realistic than stock, but, the recoil unit somewhat worked once, it retracted, then It hung up before returning. One thing I did notice, the track recoil is reduced with the new board.
You have to rewire the Taigen recoil/elevation unit or it will not work properly. On Clarks page towards the bottom is the directions on how to do it,
"Asiatam unit recoil installation" With the Sony remote you can change the track recoil strength also.
