The speaker I'm using in that tank is 4 Ohm 10 Watts speaker & I didn't use amp. I have seen people using from 15 to 35 Watts amp. So, any amp should be good though. You may also need DC converter because all amp I have seen require 12V. There is a guy at facebook that tested many amp. If I can find which one he recommend, I'll post here.
