RE: This might be a balance question or problem
Adjusting the trim to correct this will work fine. I set up my transmitter to put in downthrust at full throttle. I did it with the skimmer at first but the problem I ran into was that as the battery wore down the motor ran slower at high throttle settings and landings required a little more up elevator.
