You can get by with a wing that is close and even if it has ailerons it would be fine as long as it fits the wing saddle . Being held on with rubber bands makes it a lot easier . I have changed wings a few times and sometimes ended up with a plane that was better than I started out with . I think most of the Hobbico Super Stars had ailerons so if you ended up with a wing that has ailereons the plane will probably fly better . You most likley will have less dihedral because it won't need the self correcting tendancy . I bet one of the guys at your club will have a wing that would work . I know I do . Thats why saving stuff is a good habit to get into .
