Originally Posted by
sierra_bravo
I'm very sorry to hear that. Hopefully you will be able recover quickly. Thanks for such a great motor for such a low price. As for the rebuild kit I was planing on buying
this one from home depot and also for the prop adapter I was planing on using something like
this. Also if I pay for the engine today when will you be able to ship it.
-sam
That would be a good fuel filter to use in the tank, but that is not a carb rebuild kit like you will be needing. You need to wait and see which number carb you are actually going to use, then order a rebuild kit from someone like
www.sepw.com or
www.jackssmallengines.com
Also, that would not be a good option for a prop hub. It won't have enough surface area for the prop to seat against. You need one that looks something like the photo below. Try
www.lambertsrc.com, or
www.jagengines.com and see if they have one or will make you one for a Homelite 30cc. (A hub for a Homelite 25cc would be exactly the same.)
These are actual pictures of a Homelite 30cc.
AV8TOR
