Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Conversions
Homelite 26cc gas engine conversion help >
Old 08-06-2015 | 12:03 PM
  #76
Originally Posted by av8tor1977
Interesting idea, but the real starter cone only costs 7 bucks. If you attach a bolt to it with a nut and two star washers and tighten it good, it won't slip. Actually, I've done it without the star washers and it didn't slip. ...
AV8TOR
I am happy your approach works for you and likely will for anyone using it. I had tried a similar approach, but even with a geared chuck on my drill motor, I could not tighten it down enough to keep the bolt from slipping in the chuck.
Several considerations drove my use of the hole saw and mandrel. One was that I had all the material at hand, since I used the insert from the Sullivan starter, and I already had the hole saw set. But, most important to me was that the shaft for the hole saw mandrel had flats on it for the drill motor chuck to tighten down on to keep it from slipping; and that the nut securing the hole saw to the mandrel, in combination with the hole saw being keyed to the mandrel, made the hole saw to mandrel combination slip-proof.
And so, it is what works for me; other approaches will work as well for many people. Good luck with them.
Sincerely, Richard
Old 08-07-2015 | 10:17 AM
  #77
av8tor1977's Avatar
All good points. I didn't mean to offend nor belittle your idea. It is a good one.
Sierra Bravo: Since you are getting close, I'll mention the starting procedure. First close the choke tightly and open the throttle fully, and make absolutely sure the ignition is off. (In your case, with the magneto, that means that the magneto grounding wire will be NOT connected when it is "ON" to start. You connect the magneto wire to ground to kill the engine.) Then hand flip the engine while watching the fuel line. You should see the fuel advance with each flip of the prop. When the fuel reaches the carb, give it two or three more flips, then stop. If you don't see fuel being pulled up to the engine, you either have an air leak in your fuel system, or something wrong with the carb. Anyway, then turn the ignition on, close the choke firmly shut, open throttle to about 1/2, and give it a spin with the starter. As soon as the engine starts for a moment, stop spinning it. Then retard the throttle to just above idle, open the choke, and spin it again until it starts. Then, once the engine warms fully up, you can start tuning it. You tune for highest rpm on the high speed needle, then richen it about a screwdriver blades width, and tune the low speed needle for best idle and transition to full throttle. One needle affects the other, so you may have to go back and forth on the needles to get it dialed in. Start with both needles about 1 1/2 to 1 3/4 turns out from lightly seated.)
AV8TOR
Old 08-07-2015 | 11:25 AM
  #78
All good points. I didn't mean to offend nor belittle your idea. It is a good one...
AV8TOR
No problem, no offence taken. I am used to having to qualify my projects with my wife. All your help is very much appreciated. I have added your startup tips to my files also. Thanks.
Sincerely, Richard
Old 08-07-2015 | 12:26 PM
  #79
sierra_bravo's Avatar
thanks for the start up tips av8tor.
I got the servos installed and hooked up and here is what the(for the most part) finished tail section of the fuselage looks like.
I'm going to buy some white electrical tape to made the edges of the plane look cleaner since right now they aren't very nice. Hopefully tomorrow i'll be able to install the motor
-Sam
Name:	2015-08-07 12.25.59.jpg
ID:	2113133   Click image for larger version
Name:	2015-08-07 12.26.06.jpg
ID:	2113134   Click image for larger version
Name:	2015-08-07 12.26.12.jpg
Old 08-07-2015 | 01:22 PM
  #80
av8tor1977's Avatar
Well, on an engine with electronic ignition, if the engine is accessible I have another preferred starting technique. Once you have fuel to the carb, open the throttle and then hold your thumb tightly over the carb while turning the engine over by hand. When you feel your thumb (or finger) get wet, stop. Then turn the ignition on, set the throttle just above idle, and give it a hard flip. Doing it this way they will usually start on the first or second flip, and surprise the hell out of everyone at your field. This will also work with some magneto engines, but a lot of magneto engines are better started with an electric starter, the Homelites being among them.
Sierra: Nice progress on the plane! I also see a good old "Ugly Stik" in the background. Do you fly it? I have a Giant Ugly Stik with a 50cc twin cylinder gas engine on it and I love it!
AV8TOR
Old 08-07-2015 | 03:30 PM
  #81
I imagine your second method is something like what Flite test did in this video(skip to around 3:45 to see what I mean) and that had a magneto star. Also the second way to start the engine sounds really similar to priming(and hand starting) a glow engine where you cover the carb while at full throttle to draw in fuel then go to idle but instead of turning on ignition you connect the glow plug starter and start flipping. As for grounding the ignition coil cant I connect the cables from the ignition coil to a small switch like this and when I want to start the engine I would flip the switch.
Also I still do fly the ugly stick, pretty much every time I go out to the field because it's such a good flier. I use it to practice some basic acrobatic maneuvers like loops, rolls, inverted, and stall turns.
If I get the engine mounted tomorrow then I post some photos.
-Sam
Old 08-08-2015 | 01:24 PM
  #82
av8tor1977's Avatar
The switch you indicated looks like a momentary switch, whereby it is always on until you push it, then it is off. But when you let go, it is back "on". It would be much better to use a toggle switch that will stay off when you switch it.
AV8TOR
Old 08-08-2015 | 03:09 PM
  #83
On the radio shack page for the product it says that it's toggle switch. But I didn't link to the radio shack page because for some reason there was no photo of the switch. But as long as a normal toggle switch will work then I'll pick one up next time I go to radio shack.
-Sam
Old 08-11-2015 | 11:25 AM
  #84
I got the shaft threaded the prop installed and put some new oil on the piston. I got some photos of the prop installed but not mounted to the airframe.
The locking nut does not thread all the way so I probably have to go back to the machine shop to get the hub trimmed down a bit. I could also sand down the center of the prop to make it thinner.
-Sam
Name:	2015-08-10 21.15.41.jpg
ID:	2113946   Click image for larger version
Name:	2015-08-10 21.15.49.jpg
ID:	2113947   Click image for larger version
Name:	2015-08-10 21.15.56.jpg
ID:	2113948   Click image for larger version
Name:	2015-08-10 21.16.05.jpg
Old 08-11-2015 | 12:47 PM
  #85
av8tor1977's Avatar
Don't modify the prop; that's dangerous. Wouldn't it just be easiest to get a longer prop mounting stud?? You really need a large flat washer under that nut against the prop anyway.
If all else fails the Top Flite or Zinger props are thinner at the hub....
AV8TOR
Old 08-11-2015 | 05:12 PM
  #86
Yeah i though that moding the prop is a bad idea due to is getting badly unbalenced and losing strength. The engines crankshaft is the prop mounting shaft so i cant make it longer. I have a flat washer( you can seee it in a photo) but if i put if on there would'nt be enough thread for the nut. I'll have to look into a topflite prop if I cant find another solution.
-sam
Old 08-16-2015 | 05:50 AM
  #87
-Sam
Strongly suggest you remove the starter pawls from the flywheel. Drive the pins that the pawls rotate on from the back of the flywheel. Remove the pins and the springs also.
While you are at the machine shop, have them cut down the fins on the flywheel, but NOT below the hub level. The prop hub is plenty thick, I suggest you thin in down enough to allow the use of the thick washer and the locknut. Radio Shack here in Guilford is out of business, but Ace hardware or true Value should have toggle switches. JMHA.
Sincerely, Richard
Old 08-16-2015 | 04:21 PM
  #88
av8tor1977's Avatar
As I understand it, your crankshaft goes all the way through the prop hub and then becomes the means for attaching the propeller. An easy fix is to just have the machinist cut off the shaft 3/4" past the end of the flywheel when it is mounted. Then you can obtain and screw a stud into the prop hub adapter, long enough to engage the prop hub by at least 3/4", and also long enough to allow mounting of your propeller, a proper flat washer, and propeller nut.
AV8TOR
Old 08-16-2015 | 04:32 PM
  #89
now I see what you meant. I'll either do that make the top of the hub thinner like spaceworm said. I did find a source for the coroplast for the wings. My local piedmount plastics sells 4'x8' 2mil sheets of coro for $11 a sheet. To save some waight I'm going to make the wing out of 2 mil coro not 2 and 4mil coro like the plans said. I plane to mount the motor with some round 3/4" spacers and the bolts coming from behind the firewall.
-Sam
Old 08-17-2015 | 07:38 AM
  #90
av8tor1977's Avatar
When you assemble everything for the last time, use Loctite on the crank threads and the stud that will screw into the prop hub to hold the prop, washer, etc. Let dry overnight, then bolt on your prop without Loctite.
AV8TOR
Old 08-17-2015 | 07:53 PM
  #91
A little bit of advice sierra-bravo, when building a spad they tend to come out tailheavy so there for use the mounting postion of engine to balance the plane so you won't have weight in the front that you don't want.
Old 08-18-2015 | 04:20 AM
  #92
-Sam
Just curious, how much weight do you save with using all 2mm instead of 2 and 4?
Sincerely, Richard
Old 08-18-2015 | 10:00 AM
  #93
Theoretically 2mil coroplast would weight half as much a 4mil coroplast but I doubt thats true. As for the wing making it out of 2mil coro would make it lighter but by how much I dont know. If 2mil coro did weigh half as much as 4mil coro then a all 2mil wing would weigh 1/3 less then an 2&4mil wing
I think
-Sam
Old 08-18-2015 | 02:59 PM
  #94
I think
-Sam
Well. according to Professional Plastics website, (http://www.professionalplastics.com/...ifications.pdf) 2mm Coro weighs 92 pounds per 1000 sq ft, and 4mm Coro weighs 150 pounds per 1000 sq ft, So the weight difference is about .6 to 1, not far from your guess. On the SPAD website there is a 25 cu inch gasser profile that uses 2 mm for both top and bottom of the wing. Good luck.
Sincerely, Richard
Old 08-24-2015 | 07:08 PM
  #95
So i didnt really do much more on the plane or the motor. I did have a question though. If the outlet holes were drilled in the muffler but no outlet tubes were installed would it make much of a differnce to the power or sound of the motor. Im not going to run the muffler without tubes but it was just something I was wondering about. Also generaly how loud are 30cc converted homelites with 16" props because I'm not sure if my flying field has a sound limit or not.
-sam
Old 08-28-2015 | 11:58 AM
  #96
av8tor1977's Avatar
It would be a little louder without the tubes, power would probably be not much different. I wouldn't do it myself. The noise shouldn't be an issue, they have a lower exhaust note than glow engines and generally aren't as offensive a sound as perceived by most people. An 18 x 6 prop will probably lower the rpms a bit and make it quieter, and would really be a better prop for your SPAD anyway.
AV8TOR
