RCU Forums - View Single Post - Why do we need a Fuel Solenoid?
Old 06-27-2015 | 06:16 PM
gunradd's Avatar
gunradd
My Feedback: (9)
Originally Posted by Vettster
Ok.. I kinda see what your getting at. But the pump would not activate till it was told to add the kero, and at that same time is when the solenoid would open.
As far as keeping the prime.. The pump will not let fuel thew unless powered up. Again acting like the solenoid.
Thoughts to ponder?
If the pump didn't turn on until switch over you would never get ignition....
Your ignition fuel goes through a different valve to get the fire started and go into preheat. It's not until switch over(half way through the start) does the main fuel valve open to finish the start and run.
