RCU Forums - View Single Post - Homelite 26cc gas engine conversion help
Old 06-27-2015 | 06:44 PM
  #31
av8tor1977's Avatar
av8tor1977
Well, I don't want to scare you, but a prop on a .40 size glow engine for example, will cut you badly. A prop on a 30cc engine will literally take body parts right off!! Also note that many magneto engines are quite difficult to hand start. You may need to come up with a stout starter to get the engine going. A cheap but workable option is to buy a propeller cone and silicone insert, and use a good battery powered drill as a starter.
Give them a call at Carr Precision at that number on the post I sent you.
AV8TOR
