James,
That is exactly what I was going to do with the wheel-pants. There was a discussion early in this thread about this very issue. I even bought the Sig wheel-pant supports mentioned by David M. or David C. (I forget which one). However, when I got started in the assembly process, it was apparent that it would have been more trouble than I wanted to deal with. Especially since I wanted to put different main gear on it in the short-term furture anyway. Check out these mains:
http://www.aero-works.net/accessorie...ear/index.html
They fit the 60/90 size Aero-Works Edge, so with some pretty minor retro work they should work fine for the VF Edge, and jazz up the appearance too. I could have sworn I saw wheel-pants there before, but I didn't see them today. I'm sure Stans or one of the other suppliers will have them though.
David - sorry about the confusion you are right, I gave bad info.
Weighed the Edge last night on a very innaccurate scale with everything but Battery and Belly-Pan. Total was 6.5 lbs. I am allowing for a 1 lb. deviation and shooting for a AU Wet weight of 7.75. Will take to local FEDEX and have weighed on Digital scale there. If my scale is anywhere in the right neighborhood, I am pretty happy.
John
