RCU Forums - View Single Post - DA 50cc
Thread: DA 50cc
Old 07-01-2015 | 10:40 AM
av8tor1977's Avatar
av8tor1977
When I converted my Stihl 62cc chain saw engine, I had to make a special intake manifold adapter out of aluminum. I then used a phenolic spacer to isolate the carb, but the carb screws still screwed right into the aluminum adapter. I had all kinds of running and tuning problems. So I made another phenolic adapter that had the carb screws thread into it instead of into the aluminum adapter. Then it worked perfectly. The carb mounting screws were transmitting enough heat to the carb to cause the problems.
AV8TOR
ID:	2106777   Click image for larger version
ID:	2106778   Click image for larger version
ID:	2106779   Click image for larger version
ID:	2106780   Click image for larger version
