RCU Forums - View Single Post - Capiche 50
Thread: Capiche 50
Old 10-16-2003 | 11:16 AM
  #1633
Luke 3D returns's Avatar
Luke 3D returns
Default RE: Capiche 50
Well Well Well!
It will be interesting to compare tach readings e.t.c, particularly side thrust now there are 3 up and coming capiches at elmbridge.
Dad has put another degree of right thrust in. I think he said the amount programmed into the kit was 2 degrees. It definitely needed more with the Saito 72 because mine after trimnming in vertical climb at fullpower wanted to do a control line circuit at idle. Now mines got 3 degrees, and a bit more up thrust( it seemed to do walls a lot better inverted when i had exactly the same movement either way) I will see how it goes with these hopefull improvements on sat morning at addlestone.
