RCU Forums - View Single Post - Why do we need a Fuel Solenoid?
Old 07-02-2015 | 02:13 PM
  #42
KC36330
Originally Posted by Jgwright
A turbine will not continue running without fuel pressure. If the pump stops the engine stops it is that simple.
did i say that power loss to the pump wouldn't stop the turbine?
the question asked was what is the purpose of the solenoid, so once again, the solenoid provides a means of immediately stopping fuel flow to the turbine. shutting off the power to the fuel pump doesn't immediately stop the flow of fuel.
if you don't believe that take a fuel pump and prime it, use a AA battery and pulse the pump every 1/2 second by contacting the battery to the leads on the pump, the stream of fuel out of the pump will be a steady trickle, do the same to a solenoid and it'll be a broken stream.
