RCU Forums - View Single Post - Passion V2 Yellow
Old 07-02-2015 | 09:59 PM
griff7166
Default Passion Yellow design 2nd build thread
((((((THIS IS A YELLOW PAINT DESIGN THE "V2" REFERS TO THE SECOND BUILD THREAD ON RCU NOT THAT THIS A DIFFRENT PLANE OR REVISED AIR FRAME)))))
I was blessed to have the Mike Muller and BJ Park allow me to do some test flying and document the build process. the Plane arrived all in tact with the usual wood crate, there where not any blemishes . For this build I will be using the flowing components.
Hacker Q80-14
Jeti meaon 90 esc
all seacraft arms and carbon push rods.
I am also using 6 MKS X6 hbl575 servos ( this servo is awesome for pattern
the fist thing that I found that the hole is way to small for the q80. so I had to apace it back 1.5 inches. the way I did this is I used a 2.5 mm end grain carbon balsa cut out a circle to reinforces the nose. then a f3a q80 mount. I ran a 2 in 6/32 bolt from the front through the mount ans a 1/2 secraft spacer with nut and washer then another q80 mount to for the motor/ with all if this I was able to clear he nose
After this I moves on to the gear main and tail nothing here just normal stuff/
ID:	2107072   Click image for larger version
ID:	2107074   Click image for larger version
