RCU Forums - View Single Post - slalling when brake
Old 07-04-2015 | 08:16 AM
Anthoop's Avatar
Anthoop
Originally Posted by bram321
what if there the wrong way it will stall when brake. it can just be ticking over not moving and I brake it will cut out
If the car is not moving but the engine is idling fine and then you apply the brake and it stalls...then your idle screw is not set correctly.
The idle screw maintains the minimum idle speed.
