Originally Posted by
siclick33
Apologies for a couple of (possibly) obvious questions but this is all I can think of with the limited info available:
For the 'invert' option, are you clicking 'Write All' on the software after changing the orientation in the software.
If the aileron correction looks too small, can you confirm that the learning process was done without any limited travel/rates turned on?
Thanks for the input, So yes I get it to sync up, go to the options tab and click invert in gyro set up, then go back to the first tab and click 'Write All' and nothing seems to happen.
The only othere gyro I have are 5 Iceman gyros, and when you hit the send/update button it shows you its updateding and then the gyro moves the control serfaces, and the update has admedit effect right then and there.
Im going to try to see if they had a manual to down load, I admit I had a lot going on while I was trying to do this, dang cable guy.
Im also going to rebind it, and try the set up again.
