Originally Posted by
downunder
That's written by Hobbico, not by the OS factory. I suspect when it was written all current OS 2 strokes had a one piece crankcase which obviously means you can't rotate the non existent front housing
. The early Max-H 60/80 with the rear drum valve had an extra drive slot marked R for reverse rotation and machined 90 degrees from the normal slot.
What was written by Hobbico? Is there a post or two missing?
