RE: UCANDO60 range check problem
Can you swap out receivers to see if that is the problem? If not, unplug all the servos, and plug them back in one at a time and do a range check for each one to see if a servo is causing the problem. Also, make sure your antenna is not touching any wires or servos and that it is extended fully. I wouldn't fly the plane as it is now.
