Originally Posted by
mr_matt
Falconwings I don't get it. Is the ball supposed to be able to rotate, or are those spacers there just to provide clearance for the ball link? I don't see how torquing that bolt and nut would pre-load a ball link?
Matt, you only use one spacer on one side. When you tighten the bolt, it puts pressure on the spacer but the spacer slips inside the clevis ID, so it doesnt get preloaded. A preloaded clevis will lead to early wear of the bearing, deformation and eventually unwanted slop. So if you want ultra precise control and minimum slop....that's the way to go.
