RE: Engine Placement on AT6 does 1/2 in matter ?
The 1" forwad will change the CG and make the plane more nose heavy. If you have weight in the tail section you might be able to remove it. As long as the CG is where the plans or instructions call for you should be OK. You have probably thought about fitting the cowl already but if not consider what to do before you decide on anything.
