RE: UCANDO60 range check problem
hey mr. wilson i tryed unpluging the servos like you said but that did,nt help at all
Hey Bryan the only servo extensions i can twist up, is the y that i have on the alerons every thing else is almost to short as it is , i just can barley get enough slack from the elevator, and the rudder to plug into the receiver, mind you they are behind the throttle (ie Back half of the plane).
