RCU Forums - View Single Post - Metal Track for Tamiya JS-2!!
Old 07-17-2015 | 07:47 AM
  #33
Pcomm1.v2's Avatar
Pcomm1.v2
Tamiya JS-2 Builds: I purpose my Tamiya builds as IR fighters and for that use I like to usually run plastic kit tracks when possible. I use the Tamiya KV-1 plastic kit tracks on the red star JS-2 and they run great using the JS-2 drive sprockets, no issues. Tip: For the IR red star JS-2 I left the split hatch off and saved those delicate parts for later shelf queen status.
The hull fronts do use a simple home made aluminium brace and a Sherman metal elevation arm from ETO Armor, the only modifications to this otherwise exceptional, well running model. The other two JS builds run the JS-2 kit tracks and are similar IR builds.
Tamiya KV-1 Builds: The two KV-1 builds required custom one off modifications to become superior IR runners as the stock kit hull build up is a dismal runner.
The first KV-1 without markings runs Impact metal tracks and both KV-1 hulls are Daryl Turner Designed metal braced where it counts with his one off custom spring return idler systems; ETO Armor Black motors; Impact 8T pinion gears and ETO Armor gear reduction units for scale speed.
John
ID:	2109689   Click image for larger version
ID:	2109690   Click image for larger version
Name:	3 Czech-JS-2.jpg
ID:	2109691   Click image for larger version
Name:	4 KV-Impact-Tracks.jpg
ID:	2109692   Click image for larger version
ID:	2109693   Click image for larger version
ID:	2109694   Click image for larger version
Name:	7 Lift-KV-deck.jpg
