I was using a 4s battery on the Rx side for the ESC/Motor/Servos and apparently it was to much. The problem went away as soon as I switched back to a 3s 11.1v. The small mini servos I'm using for aileron's must be incompatible. I was stumped actually, the esc says it's rated to 4s and the servos should get the same 2A must be leakage.
