Charging at the overnight rate for a full 14 hours is advised for new batteries (some call this the forming charge)but not necessary thereafter and typically 8 hours the night before is fine for Nicd or Nimh.
Be carefull about excessive cycling when you do get a capable charger as all the batteries have a finite limit on cycles . No need and not desirable to cycle every time you go out.
John
