RCU Forums - View Single Post - Incidence problems using Robart incidence meter
Old 07-20-2015 | 11:35 AM
Flyboywbl's Avatar
Flyboywbl
Mounted this way it reads between -.25 and .5 degrees. I know it's hard to see the degree reading in the picture but you can tell that the bubble level is off in the second set of pictures. In this case, I would have to shim the trailing edge up to get it back to level with the datum plane.
ID:	2110265   Click image for larger version
