So i found out the diameter of the dle 30cc crank shaft. Its 5/16" which is 1/16" to small. But i could drill it out to 3/8" then use a tap to thread it so i can screw it onto the homelite crankshaft. What do you think. Also I found out about ch ignition which sells some conversion parts. I called and they said that they would email me later to tell me if they have a homelite prop hub.
-sam
