Originally Posted by
EXT2Rob
Alright, so enough "member measuring"
(another great line).... and let's forgive our member (no pun intended) for perhaps going off, er, half-cocked, hmm?
...Let's get with the technicals.... So would these "high voltage" Lipos or LiHVs have a different Storage Voltage setting as well?? I'd guess "Yes". So that'd be another change in the charger firmware. And there ARE chargers out for these things too? Hmm. I could see where the slightly higher voltage would give you a bit of an advantage at the top end for speed, but longer runtime?? I don't know. Whatta you think guys?
well the 2 in the original link do show some pretty high mAH ratings so yea I think the 8k would run quite a long time, but the voltage increase itself shouldn't add any as you would more then likely have to have the cutout set higher(just my guess maybe the all knowing flyboy who came could shed light on it).
