RCU Forums - View Single Post - Homelite 26cc gas engine conversion help
Old 08-05-2015 | 12:42 PM
  #68
av8tor1977's Avatar
av8tor1977
You also need to prepare yourself for starting the engine. Homelites with a magneto instead of electronic ignition are quite difficult to hand start. And a standard glow engine starter doesn't have enough power to turn them over. The cheapest/easiest route is to buy a starter cone and insert, and install a long 5/16" bolt in it with a nut. You can then chuck that bolt into a good battery powered electric hand drill and easily start the engine.
http://www3.towerhobbies.com/cgi-bin...?&I=LXL400&P=7
http://www3.towerhobbies.com/cgi-bin...?&I=LXL404&P=7
AV8TOR
