RCU Forums - View Single Post - Os46 la
Thread: Os46 la
Old 08-11-2015 | 10:24 AM
RBACONS
First, Have you peaked the high speed needle and then backed off a few clicks? And have you confirmed that when you look in the carburetor with the throttle all the way back, that the throttle barrel is slightly open (1/16" or so)? If so, when you go to full throttle, and then lower the throttle back to idle, does it die immediately or speed up and die, or slow down further and then die?
